Hello Guest it is September 08, 2026, 11:13:26 PM
Author Topic: Mach3 +Probotix+MP3000  (Read 11219 times)
« on: March 22, 2010, 10:38:10 PM »
Hi all,
New here needing help if possible. Not too sure where to start but here goes, i have Mach 3, DTHC MP3000 from Candcnc and stepper driver boards from Probotix. I have everything connected as per all instructions, have tuned motors, licensed copy of Mach3 and no luck moving motors. Well i have had movement but only when the motors feel like it! I have had to manually wire my driver boards to the MTA150 b.o.b of the MP3000 as they are usually suited to gecko drives. I know this is an absolute long shot and very vague but hopefully someone here may have some answers. I can try my best to answer any questions
Thanks Andrew
Re: Mach3 +Probotix+MP3000
« Reply #1 on: October 20, 2010, 06:53:50 PM »
Give Len at probotix a call. the driver maybe no good. I had a problem with a couple  of drivers from them were the motor moved in one direction no matter which way you jogged it.  They will help thru any problems there are good people and stand behind their products!
Gary K
