Hello
Guest
it is
November 13, 2026, 09:50:47 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
(5 axis ) C/B axis motors not moving pleas help
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: (5 axis ) C/B axis motors not moving pleas help (Read 10977 times)
hamooteh
3
on:
March 19, 2010, 03:59:49 AM »
Hi all
I finally i got my system built . im working on a 5 axis cnc router. when i run my g codes mach shows all the axis moving fine on the diagnostic page. but when i run my motors i got only 3 motors spinning (the xy and z) my C B rotational axis are not moving. i have changed the pins and the other motor which was on the C and B was working ok , which means mach is not sending signals for the C and B . this is a sample copy of my g codes i set my (step per) for the rotation axis 4.4 200x8= 1600/360. im usin a DB25 brakoutboard
O0012
N5 G90 G40 G80 G17
N10 M6 T1
N15 M3 S1000
N20 G0 G90 G43 Z2.
N25 X-495.711 Y-826.236 C63.38 B-90.
N30 Z-133.311
N35 G1 X-488.559 Y-822.652 F200.
N40 Z-190.
N45 X-492.685 Y-814.419
N50 Z-133.311
N55 G93 F9999.9 B0.
N60 G94 X-474.299 Y-815.505 F200.
pleas help
thanks
Logged
Graham Waterworth
2,785
Yorkshire Dales, England
Re: (5 axis ) C/B axis motors not moving pleas help
Reply #1 on:
March 19, 2010, 07:17:22 AM »
What happens if you run this code
G00 G91
X1.
Y1.
Z-.1
C10.
B10.
M30
Graham
Logged
hamooteh
3
Reply #2 on:
March 19, 2010, 04:09:50 PM »
Graham
thanks for your replay, when i tested your code, again the xyz axis moves and the c b dosen't, but ii can see their axiss numbers moving in mack and the motors are dead.
thanks
mo
Logged
hamooteh
3
Reply #3 on:
March 22, 2010, 12:30:15 AM »
hi
tha problem was solved, it was caused by a wrong parallel port number in the port and pins settings
thanks
mo
Logged
Print
Pages:
1
Go Up
« previous
next »
