Hello Guest it is November 13, 2026, 09:52:00 AM
Author Topic: Can get spindle to respond  (Read 9759 times)
« on: March 18, 2010, 07:35:44 PM »
I am running Smooth Stepper with a Campbell card. I can power up the system and the spindle relay will be out and the spindle has zero volts.Am using step and direct signal. I can power up the spindle. Relay will pick up and respond to S command. I can shut off spindle. Relay drops out but .5 volt remains on 0 to 10 volt analog signal and spindle sits and just turns. It will still respond to S command. If I power spindle back up. It will not respond to M5 or to S0. What have I done incorrectly.
racear
Re: Can get spindle to respond
« Reply #1 on: March 19, 2010, 02:21:15 AM »
Can you attach your xml please.
