Hello Guest it is November 13, 2026, 10:36:26 AM
Author Topic: Mach Threading  (Read 12119 times)
Mach Threading
« on: October 02, 2006, 03:13:30 PM »
Hi
I just wnated to confofm something. I am retrofitting (well rebuilding) an old lathe. As part of the control, the spindle motor had to be turned on manually and the speed set manually. However the machine is equipped with a spindle speed sensor (both a single pulse per rev and multiple pulses per rev). Hence I'm assuming this machine worked by matching the feedrate to the spindle speed. Does Mach work in this way?
I.e. can I thread without having speed control from the PC - but I have got a spindle pulse going into the PC?
Re: Mach Threading
« Reply #1 on: October 02, 2006, 10:10:14 PM »
Yes mach3 can be used to set the speed of the spindle AND you can also use the sensors to pick up the spindle speed. I used the one From PMDX  and from PC4CNC
Hope that helps
Brian
www.newfangledsolutions.com
www.machsupport.com
Re: Mach Threading
« Reply #2 on: October 03, 2006, 02:26:15 AM »
Hi Brian
Sorry but not quite the answer I was looking for. Can threading be done without spindle speed control but with feedback?
Re: Mach Threading
« Reply #3 on: October 03, 2006, 06:20:19 AM »
Yup that can be done too :) Just hook the spindle speed sensor to mach3 and you should be good to go.
www.machsupport.com
