Hello Guest it is November 13, 2026, 05:10:18 PM
Author Topic: Voltage reference  (Read 11417 times)
Offline N4NV
  •  398 398
Voltage reference
« on: March 14, 2010, 05:29:29 PM »
I am installing a Pokeys.  All of everything on my CNC machine is powered by a regulated power supply +5V, +10V and +24V.  Nothing is powered by the USB from my computer.  It appears that the Pokeys gets it power from the USB port of the computer.  How should I wire it so that things like switches, encoders etc will reference properly?  For instance, my encoder gets its +5V from the power supply.  If I wire the channel A and B outputs directly to the PoKeys, will it still work?  Also, I use Hall effect switches for a lot of functions on my machine.  They typically have +5v, Gnd and a Output.  If I power the Hall switch from my power supply and connect the output to an input of the Pokeys, will it work?
Vince
Offline borisz
  •  220 220
    • www.poscope.com
Re: Voltage reference
« Reply #1 on: March 15, 2010, 01:36:28 AM »
Hi!
You should connect all GNDs. GND is the reference.
regards
Boris
