Hello Guest it is November 13, 2026, 09:35:22 AM
Author Topic: THC ongoing  (Read 10249 times)
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
THC ongoing
« on: March 11, 2010, 07:48:00 AM »
Not strictly a mach question but...
a potential divider gets me the (negative) voltage of the torch (0 to -ve 300Vdc) down to 0 to -ve 5Vdc. I then need to feed this into an ADC. However the input range of the ADC is 0 to +ve 5Vdc. I'm looking at using an op amp as a unity inverter but that's where my electronics gets a little sketchy. I don't really want to get involved with split supply and as the input will allways be -ve I don't think it's neccessary anyway. But... do I need a negative supply to the op amp? Basically I'm a bit lost - are there any electronics savvy Mach users out there that can talk me through it or perhaps suggest a better way even.
So in a nutshell - how to feed 0 to -5V into an ADC that requires 0 to +5V.
Ian
Re: THC ongoing
« Reply #1 on: March 11, 2010, 09:15:44 AM »
Howdy Ian,
   This is the best resource I've found for electronics information.
http://forum.allaboutcircuits.com/index.php
   Some really brilliant folks there and eager to help.
Cheers to you,
RC
Offline stirling
  •  2,188 2,188
  • UK
Re: THC ongoing
« Reply #2 on: March 11, 2010, 10:28:21 AM »
Thanks Russ - I'll give it a go
Ian
