Hello Guest it is November 13, 2026, 11:50:44 AM
Author Topic: can mach record every move  (Read 13840 times)
Offline josh
  •  101 101
« on: March 09, 2010, 10:28:11 PM »
is there way that mach can record every single move on a lathe. then once it is recorded you can use that as a program.
does any one know how to do this or can it be done
Re: can mach record every move
« Reply #1 on: March 10, 2010, 01:20:16 AM »
Never used it myself but the JCode plugin looks like what you are after, you will find a link to it here http://www.machsupport.com/plugins.php
« Reply #2 on: March 10, 2010, 03:29:47 PM »
How many axis does Jcode support?
« Reply #3 on: March 10, 2010, 03:34:28 PM »
I have no idea as I have never used it, I would imagine however it would record any axis you move.
« Reply #4 on: March 10, 2010, 07:14:10 PM »
In match3 mill this have a wizard for save all movement, i used this no memory which, i suppose which match lathe also have this wizards.
regards.
Offline josh
  •  101 101
« Reply #5 on: March 11, 2010, 12:18:23 AM »
regards.
can you please explain how I can do this on my mill
I would like to use my X-box pendant and see if it will record all the move.
thanks
« Reply #6 on: March 11, 2010, 06:40:30 AM »
Have a look at CopyCat as you can use an XBox360 but you use a web cam to record the moves as you go along.
There is a manual  on it in Members Docs. It is for a mill but you can manipulate the code back for lathe use.
