Hello Guest it is October 02, 2026, 07:47:34 PM
Author Topic: Delimiter?  (Read 11477 times)
Delimiter?
« on: October 01, 2006, 08:49:27 AM »
    I've run a ah-ha controller for years that uses Artisan Pro. I'm just finishing a new machine that will use Mach3. In Artisan I could use (") as a blocker so I can right a brief description of the part program to the right of the first few lines of G-code. As long as the description starts with, and ends with quotation marks the program will not see it, and will run the program normally. I've gotten use to, and spoiled by being able to see any important info for any program that I may need to know in advance, and have it visable to read. Is there a way to do the same thing without affecting the running of the program in Mach3.
  Thank you,
        Dennis
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Delimiter?
« Reply #1 on: October 01, 2006, 11:39:59 AM »
Hi, Dennis
These work ;   (    ).
N1 (Test 2 File)
N2 g00 x10 y10             ; Vel 84 blended 120
Hope this Helps, Chip
Re: Delimiter?
« Reply #2 on: October 01, 2006, 12:25:19 PM »
Hi Chip,
   Thank you for the quick help. I tried it, and works as I needed.
    Dennis
