Hello Guest it is November 13, 2026, 12:17:53 PM
Author Topic: HELP - Data Signals on Wrong Pins on LPT  (Read 22138 times)
Re: HELP - Data Signals on Wrong Pins on LPT
« Reply #10 on: March 07, 2010, 07:15:04 PM »
OK. That got it.
I can see the direction changes on each axis and they are coming out on the correct pins.
You are also correct about looking at the direction and not the step. I am getting about a 3.3 V change in the dir pin while the step is approx 100 mv. Very hard to see. Wish I had a scope.
The interesting thing is that when I turned the a axis slaving back on, the a axis dro stopped working. Also, you can't jog the a axis if it is slaved. If you jog the x axis, you can see the a axis dir change. Cool.
Now that I'm sure of the outputs, I think I'll hook up the steppers and watch them spin a bit.
Thanks very much for your help.
Willy
« Reply #11 on: March 08, 2010, 01:11:01 AM »
