Hello Guest it is November 13, 2026, 05:46:08 PM
Author Topic: high speed encoders  (Read 32805 times)
Offline tantan
  •  130 130
high speed encoders
« on: March 06, 2010, 09:34:33 AM »
hi,
i have a pokey with an encoder connected to pin 1 and 2, nothing else is connected to it. if i configure it as a normal encoder every thing works well, but if i enable the high speed encoder option in the pokeys configuration screen the raw encoder values don't increase or decrease while the numbers 1 and 2 in the configuration screen blink while i am turning the encoder. i use the latest pokey software, i upgraded the firmware of the pokey and i use the latest mach version.
hope you help.
tantan
the netherlands
Offline borisz
  •  220 220
    • www.poscope.com
Re: high speed encoders
« Reply #1 on: March 06, 2010, 12:45:49 PM »
Hi!
Do not use fast encoders with Mach plugin yet.
New plugin which will support fast encoders is under work and shoiuld be released soon.
regards
Boris
Offline tantan
  •  130 130
« Reply #2 on: March 07, 2010, 07:09:59 AM »
oke boris thank you for your reply,
i thought that high speed mpg's where working allready, i'll wait for the update.
thanks
tantan
« Reply #3 on: March 07, 2010, 11:56:14 AM »
Fast Encoders IS supported in the latest Mach 3 plugin
I guess Boris and them are doing something in the firmware.
scott
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #4 on: March 07, 2010, 12:01:38 PM »
Will check firmware.
regards
Boris
« Last Edit: March 07, 2010, 12:06:57 PM by borisz »
Offline tantan
  •  130 130
« Reply #5 on: March 07, 2010, 12:18:00 PM »
thanks scott and boris.
if you need more info don't hesitate to ask.
tantan
the netherlands
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #6 on: March 08, 2010, 11:09:39 AM »
Can you please download latest software from www.poscope.com and test it.
regards
Boris
Offline tantan
  •  130 130
« Reply #7 on: March 08, 2010, 12:24:37 PM »
hi boris an scott,
i have tested the new software, pokeys seems to work if i open the raw values window i can see the values changing. if i have mach3 simultaneously started i see the value in mach3 (x-axis dro) changing but not i a right way; it is more or less fluctuating. if i close the raw values window of the pokeys software mach stops changing the values at all. if i open the raw values window in pokeys again the machdro starts to move again. if i check the pokeys screen in mach the mpg value changes between 0 and the value which is presented in the raw values pokeyscreen.
i hope i am clear in my explanation
thanks
tantan
the netherlands
« Reply #8 on: March 09, 2010, 06:39:39 AM »
I have sent Brian the Source code, so he can look it over, to see if I am screwing up the code in the plugin, (always a possibility), but I dont understand why it was working, and now it is not, and I havent changed that code since it was published a while back.
scott
Offline tantan
  •  130 130
« Reply #9 on: March 09, 2010, 01:30:26 PM »
hi boris and scott,
i made a bit of progress. i had windows xp with servicepack 2 installed, i installed sp3. the mpg works now but not smoothly at all. i tried different settings in the calibration window but nothing gave good results.
tantan
