Hello Guest it is September 22, 2026, 11:35:53 AM
Author Topic: Series I Bridgeport  (Read 30007 times)
Series I Bridgeport
« on: March 05, 2010, 10:58:34 PM »
Newbie CNC, but old manual mill and caster. Had the machine a while, but just decided to get a controller and am shopping craigslist for a shop computer to run a mach3 simulation. Intended use might be patternmaking or finishing castings. Time will tell.
If you think you can't do it, you're right.
Re: Series I Bridgeport
« Reply #1 on: March 05, 2010, 11:07:44 PM »
I bought a laptop computer on ebay & it worked just fine for Mach3. paid $150.00.
« Reply #2 on: March 06, 2010, 09:49:27 AM »
That's interesting. Have you run a maachine with it yet? The site cautions against laptops because the battery saver modes interrupt the flow. I am looking at the same price for a desktop and may have to add the video card to get the 32 MB called for.
« Reply #3 on: March 06, 2010, 01:51:31 PM »
This machine lacks the limit switch on the Z axis, but has the micro switches on the X and Y. Any suggestions on what to use on the Z? The cover is there, and the stop is on the quill.
« Reply #4 on: March 06, 2010, 02:06:11 PM »
Yes I ran a machime with it. Worked very well
« Reply #5 on: March 06, 2010, 03:17:07 PM »
sandcrab
Some laptops are fine others not, older laptops have more chance of working but unless you know of a certain make and model that works then no one can say if it will or wont so its pay your money and take your chance.
« Reply #6 on: March 06, 2010, 04:51:27 PM »
OK Thanks Hood.
Cancel the question on the limit switches. I dug to the bottom of the basket and found them.
New Question: This machine has the Standard Electric Slo-Syn steppers and have been asked about the voltage and current to set up a resistor in the 203 Gecko drives. The only numbers I can get off the top cover is "p/n 025805 this is alternate motor for 026744".
Any ideas for a starting voltage and current?
« Reply #7 on: March 06, 2010, 04:57:42 PM »
If its the original style huge finned type steppers then I think they are 9 amp, so if using with Geckos you will not need any resistor. As for voltage the 80V max  for  the Geckos would be about right.
« Reply #8 on: March 06, 2010, 05:24:30 PM »
Yes Hood, the large finned barrel steppers probably an '80's machine.
I'll pass that info along and see what new questions pops up.
« Reply #9 on: March 06, 2010, 05:35:51 PM »
Just been doing a bit of searching, maybe this thread will be about similar motors?
http://www.practicalmachinist.com/vb/cad-cam/bandit-controller-mastercam-179581/index2.html
