Hello Guest it is November 22, 2026, 10:19:28 PM
Author Topic: does mach 3 work with USB?  (Read 18724 times)
« on: March 05, 2010, 08:00:36 PM »
i am starting to develop ideas with a router table an wish to move from serial to USB, is this possable using Mach 3?
Re: does mach 3 work with USB?
« Reply #1 on: March 05, 2010, 08:27:29 PM »
smooth stepper
« Reply #2 on: March 06, 2010, 03:30:11 PM »
I've switched from a parallel port to the Smooth Stepper USB adapter and have been very happy. It's working flawlessly with Mach and my Taig mill even on an Acer Aspire One netbook.
« Reply #3 on: February 17, 2011, 11:11:59 AM »
guys,
I have a driver board with parallel port and I would like to use USB, so:
is possible to use a parallel port adapter for USB connection and then use MACH4, it will work well?
  •  9,378 9,378
« Reply #4 on: February 17, 2011, 11:45:02 AM »
guys,
The USB to Parallel port cables are intended for printers and will not work at present with Mach3.
As mentioned previously the smooth stepper will connect a USB port to driver board with 25 way cannon D connector and work with Mach3. I occasionally use the SS (with one machine only) and am very pleased with it.
