Hello Guest it is October 22, 2026, 07:21:40 PM
Author Topic: Screens4 not working in Vista??  (Read 12996 times)
« on: March 05, 2010, 07:58:27 PM »
Hello
I just got screens4 installed in Vista and it starts up but then locks-up and I have to use the task manger to end it, is Screens4 compatible with Vista?
Re: Screens4 not working in Vista??
« Reply #1 on: March 06, 2010, 02:33:52 PM »
Update:
After searching more I realized that Screens4 is not computable with Vista, but I keep playing with it and found if you just reduce your color depth from 32bit to 16bit it works fine, the easiest way to do this is goto your main vista screen and right click then select display settings and change the color setting on the right, worked great for me give it a try.
