Hello
Guest
it is
November 13, 2026, 09:36:08 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Tool offset problem
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Tool offset problem (Read 9486 times)
Christo
1
Tool offset problem
on:
March 05, 2010, 09:43:59 AM »
Hello All,
I am new to MACH3 but so far so good, I have 1 problem though with tool offsets. I set the tool diameters however the cut is not compensated for the tool diameter. I sure I am overlooking something as I am fairly new to CNC.
Logged
M250cnc
591
Re: Tool offset problem
Reply #1 on:
March 05, 2010, 10:02:19 AM »
Christo you can do no better than learn gcode
G40 cancels offset
G41 offsets to the left
G42 offsets to the right
You should start the offset at the beginning of your tool and cancel at the end of the tool
There is a button in Mach that gives most of the codes and an explanation
Phil
Logged
Print
Pages:
1
Go Up
« previous
next »
