Hello Guest it is November 13, 2026, 03:07:46 PM
Author Topic: Weird Stretched Screen Problem  (Read 10803 times)
Offline Dom
  •  22 22
    • Bridgeport CNC Retrofit Blog
« on: March 01, 2010, 11:49:03 AM »
I recently installed a new copy of mach 3 on a new computer (winxp) and then copied my profiles and screens over from a backup. However I have a problem whereby when I load my backed up profile the entire mach window takes up more space, all the buttons are slightly bigger as if it has been stretched out of proportion and beyond the original size. If i close and load the default mill profile from the new install the size goes back to normal.
Is this a known bug ? Can someone tell me how to fix my profile?
Re: Weird Stretched Screen Problem
« Reply #1 on: March 01, 2010, 12:33:06 PM »
Have you tried unticking auto screen enlarge on
Config, General config on the bottom pf the page under Screen Control
Phil
Offline Dom
  •  22 22
« Reply #2 on: March 01, 2010, 07:15:10 PM »
Cheers Phil! Think that's solved it. I did look under general config previously was looking for screen resolution setting like a drop down menu or something. Totally missed the auto enlarge checkbox until i went back to look for it specifically.
Thanks again!
« Reply #3 on: March 02, 2010, 04:10:34 AM »
If only all fixes were that simple  ;)
Phil
