Hello Guest it is November 22, 2026, 06:30:56 AM
Author Topic: Arc problem  (Read 10354 times)
Offline ftec
  •  88 88
Arc problem
« on: March 01, 2010, 05:12:28 AM »
The code below - genrated by hole pocketing of my CAM prog - causes my Z axis servo to die by following error on line N190. The material machined is soft plastic and this certainly is not a problem of lack of power in the Z motor.  On several occasions the latest Mach3 version xx.038 stalled and reported of an error on in the R I J values but the simulation goes fine though. G91.1 is used for I,J.
N90 (BEGIN - First Tool Macro)
N100 M901
N110 M6 T2
N120 M904
N130 G00 X175.2191 Y54.7403
N140 G00 Z5.0000
N150 M03 S16000
N160 (END - First Tool Macro)
N170 G01 Z-0.3650 F1000.0
N180 G17
N190 G03 X175.2602 Y55.0000 Z-7.0000 I-0.8691 J0.2597 F2600.0
If I change the z movement to the previous line it works, like this:
N180 G17 Z-7
N190 G03 X175.2602 Y55.0000 I-0.8691 J0.2597 F2600.0
How Mach handles line N190 is what is of interest here I guess.
Re: Arc problem
« Reply #1 on: March 01, 2010, 05:39:13 AM »
I think there is a problem with 3 axis circular interpolation if your Z axis is a lot slower than the other axis, is that the case with yours?
I think Ray L had this issue with the Z axis on his mill as he had the knee as the Z and its rapids were a lot slower than the other axis, not sure if he found a work around but seem to remember something about exact stop so might be worth trying a G61 before that move.
This should be sorted in Rev4 when it comes out.
Offline ftec
  •  88 88
Re: Arc problem
« Reply #2 on: March 01, 2010, 04:46:25 PM »
OK, thanks, have to check that. I'm using the same servo motor size for Z & X & Y with same gear ratio, Z having the lightest load so I doubt this could be an acceleration/speed/power issue. I'll check what Mecsoft has to say about this.
