Hello Guest it is November 14, 2026, 07:32:24 PM
Author Topic: STM23 Series stepmotors compatible with mach 3  (Read 11467 times)
« on: February 25, 2010, 02:28:35 PM »
hello I'm new in mach 3
i wand to build a cnc using the STM23 Series of the www.applied-motion.com that i allready have available!!
this motors have a steeper controller on board! can i use this motors with mach3??
thanks and sorry for my bad English!
Re: STM23 Series stepmotors compatible with mach 3
« Reply #1 on: February 25, 2010, 02:50:21 PM »
Looks like they should work fine as they can accept Step/Dir inputs at 5v, so as long as your parallel port can output 5V you should be fine.
« Reply #2 on: February 25, 2010, 02:53:16 PM »
this is input characteristic
STEP+/-
Optically Isolated, 5-24 Volt. Minimum pulse width = 250 ns. Maximum pulse frequency = 3MHz
Function: Step, CW Step, A Quadrature, Encoder Following, CW Limit, CW Jog, Start/Stop (Oscillator mode), general purpose
DIR+/-
Optically Isolated, 5-24 Volt. Minimum pulse width = 250 ns. Maximum pulse frequency = 3 MHz
Function: Direction, CCW Step, B Quadrature, Encoder Following, CCW Limit , CCW Jog, Direction (Oscillator mode), general purpose
EN+/-
Function: Enable, Alarm Reset, Speed 1/Speed 2 (Oscillator), general purpose
i think we are ok??? if yes ill start the construction!,
thanks
« Reply #3 on: February 25, 2010, 02:57:50 PM »
Yes  page 19, it shows the connections you need.
