Hello Guest it is November 10, 2026, 05:19:49 AM
Author Topic: run from here again  (Read 29226 times)
Re: run from here again
« Reply #10 on: February 23, 2010, 11:15:08 PM »
Thanks.....
Were you able to restart Mach and try SNL again ?
« Reply #11 on: February 23, 2010, 11:20:07 PM »
Thanks.....
It worked. Problem is if I am in the middle of cutting a part and Mach needs a reset before this work. I don't know what run from here does othe than run from where Mach wants it to run. Maybe they should rename it to "run from a random line"...:-) I guess it is a bug.
« Reply #12 on: February 23, 2010, 11:25:24 PM »
 May be related to the huge file size.
btw, I can stop, feedhold, estop, any combo many times and SNL still works every time.
Yours might also now that you've restarted Mach. It's really smart, but it can get confused at times.....mine does.
See ya,
Ruzz    ZZZZZZZZZZ zzzzzzzzzzzz
« Reply #13 on: February 23, 2010, 11:29:35 PM »
FYI
« Reply #14 on: February 24, 2010, 01:45:19 AM »
Try this the next time.
Punch in the line you want to start from and hit enter then click on that line in the code window so that the window is highlighted then press Run From Here. You should then see the counter go to zero and count down to your line then you press start and it will ask for your approval of the prep move.
« Reply #15 on: February 24, 2010, 06:16:03 AM »
Does the same. It stops at 372366 after I hit run from here.
« Reply #16 on: February 24, 2010, 06:33:46 AM »
Hey Hood, that works good here, neat trick.
(looks like a click anywhere in the window works while the requested line is highlighted)
Try this, while the code is running hit stop instead of Feed hold (I know you shouldnt....)or, EStop and rehome then enter a line # and do as you say above.
Notice after the prep move OK , the line # changes but becomes correct when you hit the start button the second time.
I think this is what Bob was seeing but nothing is really wrong, seems to run from the right line.
Russ
« Reply #17 on: February 24, 2010, 06:45:17 AM »
Will give it a go when I get home and see what happens.
