Hello Guest it is November 10, 2026, 05:19:47 AM
Author Topic: SuttlePro2 and Tab  (Read 14798 times)
SuttlePro2 and Tab
« on: February 21, 2010, 12:39:29 AM »
How I can on/off this window by means of SuttlePro2, not to use button Tab? From all list of functions in a plug-in not one does not work for me for this purpose.
« Last Edit: February 21, 2010, 09:00:07 AM by Chaoticone »
Re: SuttlePro2 and Tab
« Reply #1 on: February 21, 2010, 06:47:53 AM »
Have you tried OEM button 323?
« Reply #2 on: February 22, 2010, 01:32:59 AM »
I have not  tried OEM button 323. I cannot make it. Please, tell, how it to make!
If probably to add a sreen's.
Andrey.
« Reply #3 on: February 23, 2010, 12:55:56 PM »
I have added the button in Mach3. And it works from a mouse. But to operate by means of ShuttlePro this function it is impossible. In what there can be a reason?
« Reply #4 on: February 23, 2010, 04:29:42 PM »
Hi Andrey,
You'll need to go into: config/ config plugins/ then clck the yellow shaded area labeled config in the shuttle Pro Plug-in area. Then the shuttle Pro picture should come up with drop down menus, allowing you to configure your shuttle pro.
Just use one of the OEM buttons and put "323" in there and that should do it for you.
Hope this helps-
« Reply #5 on: February 24, 2010, 02:34:35 AM »
I so did all. But ShuttlePro does not open the lateral panel. What point of the menu in a plug-in should do it?
« Reply #6 on: February 24, 2010, 07:39:00 AM »
Some pics of what you need to do i think
Phil
« Reply #7 on: February 24, 2010, 01:28:01 PM »
Thanks, Phil!
 ShuttlePro has started to work perfectly!!!
« Reply #8 on: February 24, 2010, 04:01:48 PM »
Glad to help  ;)
Phil
