Hello Guest it is November 22, 2026, 07:07:37 AM
Author Topic: Accuracy Considerations  (Read 10990 times)
« on: September 27, 2006, 04:58:06 PM »
I am new to Mach 3 and cnc for that matter and am trying to get a feel for the accuracy I could expect after retrofitting an older mill or vmc.  Can you 'map' the different axes to get good accuracy and precision from a machine with a little wear?  What kind of accuracy could I expect?
Thanks.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Accuracy Considerations
« Reply #1 on: September 27, 2006, 06:26:34 PM »
How long is a piece of string!
There are many factors to the answer, here are a few
1. Is the machine worn
2. Are you using leadscrews or ball screws
3. Is there backlash, yaw, twist, etc.
4. What ratio of motor to screw
The list goes on and on
Mach is not the limiting factor, Mach will work to .0001" or less.
Its like this, make the machine accurate and Mach will do the rest.
Graham.
« Reply #2 on: September 28, 2006, 04:03:36 PM »
Thanks for the explanation.
