Hello Guest it is October 16, 2026, 12:25:45 AM
Author Topic: Why does this have to happen....  (Read 10258 times)
Offline gaz.
  •  23 23
« on: February 18, 2010, 06:37:31 AM »
For some odd reason lazycam wont load the full g-code into mach, it will load something like 2800 lines and then nothing else.  I have spent all morning trying to fix it and look for similar problems on the internet.
I have the licensed version, at the moment it has loaded 2450 g-code out of about 10,000.  But if i load a g-code from another programme it will work fine.
Any ideas....
Gaz.
Offline gaz.
  •  23 23
Re: Why does this have to happen....
« Reply #1 on: February 18, 2010, 07:49:13 AM »
Okay i think i have the solution if this happens to anybody else.
The lazycam has to be from the same download with the mach, so you cant download LCam after because it dosnt work properly.
And you cant install LCam from the directory of mach 3 because that dosnt work either.
So you have to uninstall all of mach and LCam and then download it all again ticking the box to install LCam at the same time, and then reload the license.
Gaz.
« Reply #2 on: February 18, 2010, 09:51:02 AM »
Thanks for sharing the resolution
Phil
