Hello Guest it is November 13, 2026, 01:47:13 PM
Author Topic: Program Safety Lockout problem  (Read 59950 times)
Re: Program Safety Lockout problem
« Reply #20 on: September 09, 2010, 08:30:34 AM »
Ok if you have no joy I will try and see what happens with that version when I get home from the workshop tonight.
« Reply #21 on: September 09, 2010, 08:31:54 AM »
no that didn't fix the problem so its not the screen and not the xml  and I'm not calling macropump.
I am using a licensed copy of Mach3 I deleted M300 from boot up just in case
« Reply #22 on: September 09, 2010, 08:33:46 AM »
what if i try just wiping Mach3 and reinstalling it?
how do I copy the license and reinstall it?
« Reply #23 on: September 09, 2010, 08:38:21 AM »
First I would try just installing Mach over the top of itself.
The files you want to save are your xml, any custom macros any custom screensets and associated bitmaps and of course you licence which is called Mach1Lic.dat and is in the main Mach3 folder. Also tooltable and offsets are stored in the macro folder of the profile you use so best just saving the whole macro folder.
Installing Mach over itself should not need replacing any files but always best to have them backed up just in case ;)
« Reply #24 on: September 09, 2010, 08:38:49 AM »
well its close when you consider I moved over to Cocoa beach, Florida from newport south wales about 10 years ago lol next time I come visit I'll have to make a point to come down your way and buy  you a couple of pints lol
« Reply #25 on: September 09, 2010, 08:41:24 AM »
files backed up will try over writing thanks I'll downlod the final version of Mach3 and use that Mach3 R3.042.040
« Reply #26 on: September 09, 2010, 08:44:54 AM »
Ha ha as long as its not pints of water, had enough of that the last day, see pic of an idiot in his companies van ;D
« Reply #27 on: September 09, 2010, 08:47:56 AM »
lol that didn't end well
« Reply #28 on: September 09, 2010, 08:48:39 AM »
so what do You do Hood
appart from help out newbies
« Reply #29 on: September 09, 2010, 08:55:02 AM »
over ridden using Version R3.042.040  no effect even when using the stands Mill xml still wont save?
