Hello Guest it is October 20, 2026, 09:43:06 PM
Author Topic: Mach2 Wizards  (Read 34111 times)
Rcav8r4u
Mach2 Wizards
« on: September 27, 2006, 01:55:59 AM »
Ya, Ya! --another Newbie!
I am running the demo version of Mach 2 ---are the Wizards enabled?  If I try to set drill size, home position etc,  it will revert back to original configuration on next change I do.
So far Mach 2 seems to work fine for what I need it for, I have tried Mach 3 but had configuration problems, so reinstalled Mach2
Re: Mach2 Wizards
« Reply #1 on: September 27, 2006, 01:15:13 PM »
Nope :( Mach2 has very little for wizards Mach3 is the one with all the goodeis :)
We can help you get your settings if that helps
www.newfangledsolutions.com
www.machsupport.com
Re: Mach2 Wizards
« Reply #2 on: September 28, 2006, 06:53:55 PM »
when you make a change to a setting you need to press the  enter key on your keyboard to make it stick.
Rcav8r4u
Re: Mach2 Wizards
« Reply #3 on: October 02, 2006, 02:19:33 PM »
Thanks Hood. You guessed it, something so simple you make me look like an idiot!  :-[                 Couldn't see the forest for the trees!
Re: Mach2 Wizards
« Reply #4 on: October 03, 2006, 01:23:23 AM »
ha ha, dont worry about it, been there, done that, got the t shirt ;)
