Hello
Guest
it is
November 11, 2026, 11:38:00 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach Screens
Machscreen Screen Designer
(Moderator:
Klaus1311
Editing VB code
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Editing VB code (Read 28757 times)
M250cnc
591
Editing VB code
on:
February 12, 2010, 07:26:55 AM »
When you open the vb code editor from a button when typing the text is all upper case
Can this be changed so the user can have full control over upper and lower case ?
Ver 1.37D
Phil
Logged
Overloaded
4,923
Re: Editing VB code
Reply #1 on:
February 12, 2010, 07:46:20 AM »
Not the case here Phil, now I'm going to be silly. Caps Lock ?
Russ
Logged
M250cnc
591
Re: Editing VB code
Reply #2 on:
February 12, 2010, 07:59:32 AM »
I'M SORRY, WHERE IS THE CAPS LOCK KEY.
No definitely no caps lock enabled
Phil
Logged
Overloaded
4,923
Re: Editing VB code
Reply #3 on:
February 12, 2010, 09:40:14 AM »
Logged
Overloaded
4,923
Re: Editing VB code
Reply #4 on:
February 12, 2010, 10:13:34 AM »
OK...then try this.
Settings tab...editor.
Works here.
Russ
Logged
Overloaded
4,923
Re: Editing VB code
Reply #5 on:
February 12, 2010, 10:15:20 AM »
......requires a restart to take effect.
Russ
Logged
M250cnc
591
Re: Editing VB code
Reply #6 on:
February 12, 2010, 10:46:13 AM »
Thanks Russ
Phil
Logged
Print
Pages:
1
Go Up
« previous
next »
