Hello Guest it is October 21, 2026, 08:56:08 AM
Author Topic: NFS Wizard not showing as licensed  (Read 30814 times)
« on: February 10, 2010, 05:25:06 PM »
I purchased the NFS Wizard and Mach Support emailed me the license file which I copied to the Mach3 root directory. I can open the Wizard and do whatever I want and then post the code. However when I click exit to Mach the code window shows "Unlicensed Wizard File" with no G-code. Is there something elase I need to do?
Re: NFS Wizard not showing as licensed
« Reply #1 on: February 10, 2010, 05:26:40 PM »
Actually I may have figured it out. The system I am playing with is running Mach3 in demo mode. I'll get it licensed the try again.
« Reply #2 on: February 10, 2010, 05:30:39 PM »
Yep, that did it. Something to look for if it isn't working for you.
