Hello Guest it is November 13, 2026, 02:29:26 PM
Author Topic: How to set your own variables in a part program?  (Read 11773 times)
« on: February 09, 2010, 03:13:43 AM »
Hi everybody,
Since I'm new to Mach3 and already searched the forum, but couldn't find an answer, would be great if I could get some here.
Well I already did some GCode programming on some other platforms, so I wondered how I can set my own variables in a part program? Is it possible to set variables in a part program?
For example: K=3 (the variable K should be 3)
                  and then I use it
                  M=K  which gives me the same result as if I would typ the command M3
Is that possible in Mach3?
Thanks for the answers, I know it should be trivial but I just can't find an answer?
best Josef
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: How to set your own variables in a part program?
« Reply #1 on: February 09, 2010, 11:10:10 AM »
You do it like this
To set a variable :-
#1=3 (use numbers #1 to #100  or #500 to #600)
#2=50
#3=[#1+#2]
#4=[0-10.5] (to set minus numbers)
To use that variable :-
G01 X[#4]
G02 X[#2] Y[#3] K[#1] F10. (etc.)
Graham
Offline olf20
  •  325 325
« Reply #2 on: February 09, 2010, 05:08:47 PM »
Thanks Graham, and Josef, I also wanted to know this.
olf20 / Bob
Mach3, Atlas Knee Mill, 4th Axis, VcarvePro, ESS, Super PID.
Been Heating with corn since 1998
