Hello Guest it is November 22, 2026, 08:26:02 AM
Author Topic: Configuring steps per unit and units per in Mach 3 - can anyone help?  (Read 27943 times)
Trying to configure the steps per unit (mm) on my Taig CNC with Stepmaster 4 axis controller (model SOP-2 ver 1.2)
The screws are 1/2" x 20TPI
Steppers are Sure step 276 oz 2.8A 1.8degree step (200 steps) 1/8th step microstepping
Units in Mach 3 are mm
To work out the steps per unit = steps per revolution of stepper motor * TPI of leadscew
Any ideas?
Re: Configuring steps per unit and units per in Mach 3 - can anyone help?
« Reply #1 on: February 07, 2010, 12:42:23 PM »
20 TPI = 1/20 = 0.05inch pitch 0.05 x 25.4 = 1.27mm pitch
so
200 steps per rev x 8 micro steps = 1,600 steps per rev
1 rev = 1.27mm so 1,600/1.27 = 1259.84252 steps per mm.
« Reply #2 on: February 19, 2010, 05:38:14 PM »
Can I configure the steps per unit in English measurements but then use Mach 3 to produce parts from metric drawings?
If I round up units per step I'm going to be a little inaccurate over the length of the bed.
« Reply #3 on: February 19, 2010, 06:11:52 PM »
You don't have to round up, just enter 5 decimal places. You won't be able to measure any innacuracies.
It is possible to configure the machine in inches and run metric g-code using G21 (I think), but it's not the preferred method.
« Reply #4 on: February 19, 2010, 06:12:25 PM »
You can go to 5 or 6 decimal places I would think.
 You can also set up in Imperial units and run metric code by having a G21 in the code if you wish.
In reality however if you think about it, the taig has screws which likely are no where as precise as the small rounding error you are talking about, I have class 5 precision ground ballscrews on my mill and they are something like 0.018mm/300mm.
Edit, Ger beat me too it LOL
« Last Edit: February 19, 2010, 06:13:56 PM by Hood »
« Reply #5 on: February 20, 2010, 01:35:47 AM »
Another way would be two profiles, one imperial and one metric
Phil
« Reply #6 on: February 20, 2010, 06:14:44 AM »
Phil
dont think that would help in this case as the OP is wanting to set the native units as Imperial and work in metric for code. As said however the reason for wanting to do this is probably misguided as the rounding error of setting the imperial screws as metric units will be negligible and the screws will probably have 100 times any rounding error if not more.
« Reply #7 on: December 31, 2013, 12:38:23 PM »
can you figure this in inch !!!  i have same set up...running test, shows pulsing too fast !!
« Reply #8 on: December 31, 2013, 12:45:06 PM »
Trying to configure the steps per unit (inch) on my Taig CNC with StepmasterNC 4- axis controller (model SOP-2 )
Units in Mach 3 are inch
 how is this figured...
 my test comes up "pulsing too fast....and where in Mach3 do I input these #rs ???
« Reply #9 on: December 31, 2013, 12:46:09 PM »
If you are running the driver test with Mach open then you will get that message, if Mach is shut down when you are running it then your computer has problems pulsing.
