Hello Guest it is November 13, 2026, 09:45:06 AM
Author Topic: New to CNCing and Mach3  (Read 28811 times)
Re: New to CNCing and Mach3
« Reply #10 on: February 09, 2010, 02:03:58 AM »
Shouldn't the Z MAX be higher? otherwise, you'll trigger the softlimits on a rapid move.
But the Z min does need to be less than zero, as that's where the cutting takes place.
Ger, Soflimits are in machine coords so Z Max should  be set as zero and Z Min the amount of travel that axis has, which will be a negative value.
« Reply #11 on: February 09, 2010, 08:36:26 PM »
Your right (as usual). Thanks. :)
