Hello Guest it is September 30, 2026, 06:40:02 PM
Author Topic: Prox Switches  (Read 17863 times)
Prox Switches
« on: February 06, 2010, 04:52:22 AM »
Can anyone tell me how to replace mechanical limit switches with prox switches and wire them to a breakout board?
  •  9,374 9,374
Re: Prox Switches
« Reply #1 on: February 06, 2010, 07:12:42 AM »
Have you decided on the type of proximity switches you want to use (make and model) ?.
Re: Prox Switches
« Reply #2 on: February 06, 2010, 08:09:32 AM »
I have some 6 - 24 volt PHD (source- PNP) prox switches that I want to use on some pneu. cylinders to indicate that they are extended or retracted. They have 3 wires :  brown (+DC), blue (-DC), and black (to load and then grd.) I am just not sure how to wire them in and I don't want to do trial and error and create smoke!
  •  9,374 9,374
Re: Prox Switches
« Reply #3 on: February 06, 2010, 08:41:40 AM »
With this type of sensor you cannot wire it directly to your BOB.
The easiest solution would, I think, be to operate the device at 12 Volts and connect the output (black) wire to a 12 Volt relay coil with the other side of the coil connecting to ground (blue) then, just in case there isn't one already fitted within the sensor, connect a diode across these relay coil connections (polarity + to black / - to blue). You can then use the relay contacts N.O. or N.C. (as you choose) to connect to your BOB and ground.
Re: Prox Switches
« Reply #4 on: February 06, 2010, 08:50:54 AM »
Thanks so much for your help. I assume that I can pick up a diode at my local Radio Shack store. Is there any specific value or size that I need to ask for?
  •  9,374 9,374
Re: Prox Switches
« Reply #5 on: February 06, 2010, 09:05:58 AM »
The diode doesn't have to be anything special a 1Amp type 1N4004 or similar would do just fine. (It just stops the back emf from the coil damaging the PNP transistor when the load is disconnected).
Re: Prox Switches
« Reply #6 on: February 07, 2010, 11:07:11 AM »
Why would he not be able to just use series current-limiting resistors and clamping diodes to the +5V on the BOB, or just a resistor divider?  Relays seem like overkill.
Re: Prox Switches
« Reply #7 on: February 07, 2010, 06:27:05 PM »
Hi Ray:
Could you draw me a schematic of what you are referring to? Thanks.
Charlie
Re: Prox Switches
« Reply #8 on: February 07, 2010, 07:06:38 PM »
Hi Ray:
Charlie
This problem is typically handled by putting a resistor in series with the 12V signal, to limit current into the BOB or PC.  Just limit the current to a few milliamps.  The resistor limits current flow from the 12V supply to the 5V supply of the PC or BOB.  A diode connected from the BOB input pin to its 5V supply ensures the voltage on the input pin cannot exceed the supply voltage.
You might want to take a look here:  http://cnc4pc.com/Tech_Docs/C11R9_3_USER_MANUAL.pdf starting on page 9....
