Hello Guest it is October 12, 2026, 03:39:27 AM
Author Topic: Mach 3 for vertical lathes?  (Read 29435 times)
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
Re: Mach 3 for vertical lathes?
« Reply #10 on: September 27, 2006, 01:35:33 PM »
Which codes woudl require the change?
Art
pabeader
« Reply #11 on: September 27, 2006, 08:04:34 PM »
Well there are a number of them...
G10 - Set to Radius programming
G11 - Set to Diameter
G70 - Inch programming
G71 - Millimeter
G33 - Constant lead Threadcut
G34 - Variable lead Increasing
G35 - Variable lead Decreasing
G53 - Cancel Part Offsets
G60 - Clear Inhibit zone
G61 - Activate Inhibit zone
G62 - DeActivate Inhibit zone
G92 & G98 - Insert Cartesian presets
G99 - Cancel Presets
G93 - Velocity/Distance feerate mode
That would be a start.
Offline ART
  •  1,703 1,703
« Reply #12 on: September 27, 2006, 09:44:20 PM »
Hi:
 Kinda what I figured. Its not so much the code, its functions you need. Some of those dont exist in Mach./ There is no way to add them, and it wouldnt be trivial to do so.
   >> This one woudl be easy, since both radius and diamter do exist.
G71 - Millimeter
  >> This is already implemented.
  >> Again, these dont exist, so impossible..
>> G53 is there, but not modally so.
  >> No inhibit zones exist to control in MAch
  G92 exists, but G98/G99 have different meanings..
  Again, not too bad..
 All in all, its a case of wanting features, not so much code changes. Sorry, wont happen in any short term..
Art
pabeader
« Reply #13 on: September 27, 2006, 10:10:12 PM »
Oh well.  Guess I'll have to write my own CNC program.  Shouldn't take more then a week or two to port the base code over from one of the other machines.  Then pretty it up.  Now if I could only get the cool driver you have...
Offline ART
  •  1,703 1,703
« Reply #14 on: September 27, 2006, 10:20:04 PM »
yeah, the driver part was the most difficult.. :)
Art
