Mach Discussion => General Mach Discussion => Topic started by: pabeader on September 24, 2006, 05:52:42 PM
Sorry if this has been answered before...
I started looking at the Mach turn screens and I notice that they all show horizontal lathes. Is it possible to change this?
thanks
You can modify all the screens in Mach by using the Screen editor, this can be downloaded from the download tab at the top of the forum.
Graham.
Tried it and I don't see a way to rotate the toolpath window 90°
Also, is it possible to change the built-in M-codes and G-codes?
bump
There is no way to turn thetool path other then setting the monitor on its side at this time :)
If you retro the machine it would not be that hard to add for you...
Brian
Personally I cant really see any need to rotate the toolpath view even if it is a vertical lathe. Hardly going to confuse the operator.
Did your old controls have a toolpath display?
There is no reason Mach can't control your machines, as long as you can interface to Mach, and in most cases thats not much of a problem.
You are right in that we don't currently have a toolpath. I could just create screens without them so that wouldn't be an issue. Yes, unfortunatly if I leave them the operators we have would be VERY confused. We'd find them leaning over all the time trying to figure it out. Might get a number of wrenched backs and things like that. :)
Seriously, though. I really do need to find out if the built-in M-codes and G-codes can be changed. Our existing programs have different usages for a number of the codes.
Gcodes can't be changes but you can change most all of the Mcodes :)
Brain
Well maybe if I can get the company to spring for 20 licenses we might be able to work something out? I could provide you with a list of the G-codes and how WE (GE, AB, Fanuc) use them and you could adjust the program to fit? Or I could do it if I had the source. Either way would be fine with me.
Set me up with the different modules that contain the G-codes. I tweak them for us. Send them back to you to be compiled into a finished program. That way all I have is bits and peices and not everything.
Just a thought
It could be added to a plugin but you are looking at one hell of a bunch of work :( What Gcodes are you having trouble with
Which codes woudl require the change?
Art
Well there are a number of them...
G10 - Set to Radius programming
G11 - Set to Diameter
G70 - Inch programming
G71 - Millimeter
G33 - Constant lead Threadcut
G34 - Variable lead Increasing
G35 - Variable lead Decreasing
G53 - Cancel Part Offsets
G60 - Clear Inhibit zone
G61 - Activate Inhibit zone
G62 - DeActivate Inhibit zone
G92 & G98 - Insert Cartesian presets
G99 - Cancel Presets
G93 - Velocity/Distance feerate mode
That would be a start.
Hi:
Kinda what I figured. Its not so much the code, its functions you need. Some of those dont exist in Mach./ There is no way to add them, and it wouldnt be trivial to do so.
>> This one woudl be easy, since both radius and diamter do exist.
G71 - Millimeter
>> This is already implemented.
>> Again, these dont exist, so impossible..
>> G53 is there, but not modally so.
>> No inhibit zones exist to control in MAch
G92 exists, but G98/G99 have different meanings..
Again, not too bad..
All in all, its a case of wanting features, not so much code changes. Sorry, wont happen in any short term..
Art
Oh well. Guess I'll have to write my own CNC program. Shouldn't take more then a week or two to port the base code over from one of the other machines. Then pretty it up. Now if I could only get the cool driver you have...
yeah, the driver part was the most difficult.. :)
Art
