Hello Guest it is October 20, 2026, 11:09:27 PM
Author Topic: Has anyone successfully threaded with version Mach3 R3.042.036?  (Read 25002 times)
Re: Has anyone successfully threaded with version Mach3 R3.042.036?
« Reply #10 on: February 05, 2010, 11:27:00 AM »
Thanks for all of your help!
Just to let everyone know version 3.042.029, 3.042.034, 3.042.035, 3.042.036 do not thread right at all!  Brian sent me a new driver to test and it fixed the threading... They will add it in the next release.
Also if you are using G95 you might want to put this code in your M3 macro to make sure the spindle is up to speed before the motion starts.
DoSpinCW()
While ((Abs(GetOEMDRO(39) - GetOEMDRO(202))) > 20) 'Wait for spindle to get up to speed!
Sleep 50
Wend
 If the spindle is not at commanded speed right when the motion starts mach will not cut the rest of the program at the commanded feedrate even after the spindle is up to full speed.
Andrew
Andrew
MachMotion
« Reply #11 on: February 05, 2010, 03:25:52 PM »
Andrew,
Thanks for replying back with info on threading. Guess I'll stay with .033 until the nest release.
