Hello Guest it is November 23, 2026, 02:26:34 PM
Author Topic: MACH3 to EMC2  (Read 10677 times)
MACH3 to EMC2
« on: February 01, 2010, 02:12:10 PM »
Hi all. Im poking a stick at EMC2 just for kicks. Im not regged on their forums yet as im not ready to give this 100% attention but i have seen many familiar names from here over there.. so... im looking for some info on the easiest way to "copy" my mach config to an EMC one. any easy way to do this? Im sure it must have come up before and since I believe Mach has its roots with EMC it must be fairly similar. I tried running the wizard but they numbers are all different, and the way they ask for them are in differently calculated methods.
Any help appreciated.
« Last Edit: February 01, 2010, 02:18:46 PM by Chris.Botha »
Re: MACH3 to EMC2
« Reply #1 on: February 01, 2010, 07:04:49 PM »
Hello Chris,
Best of luck, I don't use EMC and have no idea to help you with it.. I would contact them on the EMC mailing list that they have. They may be able to help you ..  I htink you will need to do some HAL work...
Brian
www.newfangledsolutions.com
www.machsupport.com
