Hello Guest it is September 26, 2026, 05:22:10 AM
Author Topic: Mach3 bug ?  (Read 17810 times)
Mach3 bug ?
« on: January 29, 2010, 02:40:48 AM »
This relates to a mill using ver 036 and PP
I made some gcode with some G43's the program on first loading runs through and doesn't throw any errors.
The first toolchange goes OK "Manual" when i come to the next toolchange the program halts after i hit cycle start with SOFTLIMITS MOVEMENT ABORTED
This is nothing to do with the tool length as i changed the tool length to 2mm
If i comment out the G43 it will run OK
If i take out the T06 it will run OK with the G43 line in
The G43 line is G43 H2 D0
Has anyone else gotten over this problem ?
Phil
Re: Mach3 bug ? Tool Change problem
« Reply #1 on: January 30, 2010, 11:27:55 AM »
Ok thanks for the help. ???
My code is generated by CAM
What was happening was i left the tool length offset enabled so got the error on soft limits.
Added a G49 at the end of the tool change so the next tool change didn't activate the soft limits
Hope this helps someone.
Phil
Re: Mach3 bug ?
« Reply #2 on: January 30, 2010, 11:53:44 AM »
Thanks for the answer Phil, as you say it will hopefully help someone else out :)
Re: Mach3 bug ?
« Reply #3 on: January 30, 2010, 11:54:48 AM »
Yeah but only if they do a search. ;D ;D ;D
Phil
Re: Mach3 bug ?
« Reply #4 on: January 30, 2010, 11:57:12 AM »
Yes true, then again  I may remember your issue and may remember the resolution so will be able to tell them ;D
Re: Mach3 bug ?
« Reply #5 on: January 30, 2010, 12:00:22 PM »
Unfortunately, the it's very hard to find anything with the search here, unless you know exactly what you're looking for. At least from my experience. Having an option to Google search the forum would be much better.
Re: Mach3 bug ?
« Reply #6 on: January 30, 2010, 12:00:55 PM »
Yes that's true, what would we do all do without you :)
Phil
Re: Mach3 bug ?
« Reply #7 on: January 30, 2010, 12:03:02 PM »
Phil
Probably jump for joy ;D
Re: Mach3 bug ?
« Reply #8 on: January 30, 2010, 12:11:10 PM »
Yeah just tried, i had to use advanced search, soft limit nothing, softlimit nothing, softlimits found this thread.
So be nice to Hood  ;D
Phil
