Hello Guest it is November 12, 2026, 12:45:20 AM
Author Topic: Losing Steps????  (Read 13770 times)
Losing Steps????
« on: January 29, 2010, 01:55:23 AM »
I am having trouble with my mill, it seems that I am losing steps.  The mill is set up as per my signature.
I am using an indicator mounted in the spindle, I zero out the indicator on a bar clamped to the table parallel to the Y axis, making sure to remove any possible backlash.  I then make a G1 move in the X axis of -2.953" (75mm) and then insert a 75mm Jo block.  With the feed rate set to 4 IPM the indicator reads .000.  I then remove the backlash and rezero my indicator on the Jo block, remove the block and make a g1 move in the X axis back to 0.  The indicator will read -.0015.  I did this 3 time at this feed rate and had the same results.  When I increase the feed rate to 6 IPM, I get an indicator reading of -.001 on th first negative X axis move, but it is off --.035" on the move back to 0.  If I increase the feedrate to 10 IPM I get -.006" on the negative move and -.067" on the move back to 0.  If I do a G0 move it is off almost -.185" on the move back to 0.
I've do some limited testing in the Y and Z axis and don't seem to have any issue, the indicator reads within .0005" both directions.
Any idea what might be happening?
Tom
« Last Edit: January 29, 2010, 02:05:08 AM by jagert59 »
1986 Hurco SM1 Stock ElectroCraft Servos and encoders, Larkin Viper 200 drives, Smoothstepper, CNC4PC C23 BOB, Dura Pulse GS3 VFD, Mach 3
Re: Losing Steps????
« Reply #1 on: January 29, 2010, 02:38:39 AM »
Check that you have no loose pulleys, failing that I can only think it is a problem with tuning or a drive.
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #2 on: January 29, 2010, 04:42:46 AM »
How are you 'removing backlash'? Sounds to me like you have a problem with your testing proceedure.
Happy machining , Jeff Birt
« Reply #3 on: January 29, 2010, 04:53:33 AM »
Checked the encoder attachment set screws they were ok, no pulleys it's direct drive, swapped drive with the Y axis drive, no change.  could I have a defective encoder, I have another one, would it make sense to swap it?
Tom
« Last Edit: January 29, 2010, 04:56:40 AM by jagert59 »
« Reply #4 on: January 29, 2010, 04:55:26 AM »
By 'removing backlash', I meant that I made a small move in the opposite direction to 'take up" the backlash ~.0015" that the X axis has.  I did this so that the backlash wouldn't effect my measurements.
Tom
