Hello Guest it is November 12, 2026, 12:45:19 AM
Author Topic: Change profile name?  (Read 16552 times)
Offline mr.c
  •  40 40
« on: January 26, 2010, 02:11:14 PM »
I misnamed a profile that I use. I have not figured out how to rename it. Is it even possible to rename a profile?
Re: Change profile name?
« Reply #1 on: January 26, 2010, 02:27:07 PM »
Just find the xml you renamed and then right click and choose rename, it will be, or should be, in the Mach3 folder.
Offline mr.c
  •  40 40
« Reply #2 on: January 26, 2010, 02:35:44 PM »
Thanks. I was trying to find a way to change the name from within the program and now See that I can change it at the desktop icon before opening Mach. Senior moments seem to come more regularly these days.
Offline mr.c
  •  40 40
« Reply #3 on: January 26, 2010, 03:51:28 PM »
Hood: That didn't work. I went out to the shop and booted up the shop computer. I had already changed the name on the desktop icon. I went in to Mach III through c drive machIII and renamed every file that was named Hardinge. When I open Mach III the screen profile name at the bottom still lists Hardinge.
When I first installed machIII, I set up a profile named Hardinge only to realize that it was the mill program and not the lathe program. So bottom line, I still haven't been able to change the profile name. I did reboot the computer after the name changes today. So I am still baffled.
« Last Edit: January 26, 2010, 03:54:27 PM by mr.c »
« Reply #4 on: January 26, 2010, 03:56:56 PM »
Ok go to Mach3 folder and double click the Mach3.exe, the loader should open, what do you see in the list? Is the profile you want to use in the list?
If it is the shortcut on the desktop you are wanting to change then you right click and choose properties then edit the tarket to point to the profile you want it to be, just make sure you keep the correct spacing.
Offline mr.c
  •  40 40
« Reply #5 on: January 26, 2010, 04:18:17 PM »
Hood: I see the profile names under the session profile screen but right clicking does nothing. The only options are create profile, delete profile and cancel or OK. Right clicking does not bring up a screen.
« Last Edit: January 26, 2010, 04:20:56 PM by mr.c »
« Reply #6 on: January 26, 2010, 04:20:37 PM »
I am meaning the desktop shortcut
Right click on it and properties and then change the target name to the profile you want.
Offline mr.c
  •  40 40
« Reply #7 on: January 26, 2010, 04:24:20 PM »
Hood: That worked. Thank you very much.   Carey
« Reply #8 on: January 26, 2010, 04:25:39 PM »
No problem :)
