Hello Guest it is October 24, 2026, 08:54:06 PM
Author Topic: Re-start the program from a different line  (Read 40267 times)
Re: Re-start the program from a different line
« Reply #20 on: January 28, 2010, 05:02:21 PM »
If you want to attach your xml  I will see what shows up here.
« Reply #21 on: January 29, 2010, 07:44:04 AM »
xml?
sorry I'm a noob.
« Reply #22 on: January 29, 2010, 08:14:43 AM »
You will find it in the main Mach3 folder, if you are using the standard Turn profile it will be called Mach3Turn.xml.
You will likely have to rename it before the forum will accept as  a file name can be uploaded once and I think Mach3Turn will already have been uploaded, you could copy it to your desktop and rename to saumur.xml and the forum should accept it.
« Reply #23 on: January 29, 2010, 09:07:08 AM »
Hey Hood,
I'm attaching my xml.
Anyway just to let you know I'm doing these test from my comp not the actual machine.
Still they have the same program version and everything so it's strange.
thanks
« Reply #24 on: January 29, 2010, 09:24:09 AM »
Strange, its working fine here for me, see screenshot.
What rev of Mach are you using?
« Reply #25 on: January 29, 2010, 09:32:19 AM »
I'm using the version R 2.63.
Just to make sure I'm using the From here option and then after pressing cycle that screen pops up.
« Reply #26 on: January 29, 2010, 09:35:04 AM »
Yes thats the correct procedure.
Ok try a newer version just in case thats the problem, 2.63 is very old. I will see if I have 2.63 here and see what happens.
« Reply #27 on: January 29, 2010, 09:48:13 AM »
Ok I just tried with 2.63 and right enough safe Z rather than Rapid Dia, you will need to upgrade to a newer version, 2.63 is probably 2 or 3 yrs old.
« Reply #28 on: January 29, 2010, 09:59:56 AM »
Thanks mate,
in the end we found the solution...
Thanks for being helpful as always.
C ya.
« Reply #29 on: January 29, 2010, 10:06:41 AM »
No problem :)
