Hello Guest it is October 26, 2026, 01:38:11 AM
Author Topic: Re-start the program from a different line  (Read 40369 times)
Re: Re-start the program from a different line
« Reply #10 on: January 27, 2010, 11:14:14 AM »
I noticed that when I use the option start from here it won't let me choose the position the machine will start, it automatically choose the coords of the line before I want to start...
« Reply #11 on: January 27, 2010, 12:34:42 PM »
Yes, that is normal on both Mill and Turn, just start from the next line and it will run from the one you want :)
« Reply #12 on: January 27, 2010, 01:09:38 PM »
What I was trying to say is that it I can't choose coords and it still moves the X 1st and Z 2nd...
thanks for your help anyway
« Reply #13 on: January 27, 2010, 01:13:49 PM »
Yes X should move first but only  to the value you type in as the Rapid Dia in the prep move box.
If your X is at 20mm and you type 40 for the rapid dia it will go to 40, z will move then X will go back into the dimension the line of code has. Similarly if you were initially at 100 dia and you put a 40 in the rapid dia it would move X to 40 then z would move.
« Reply #14 on: January 28, 2010, 08:04:02 AM »
Hood thanks for helping.
I understand what you are tring to say but as I told you in the prep move box I can't type anything, only the safe Z which is useless in lathe.
You are telling me to put a different value in X so the Z moves 1st, but I can't!! The boxes are greyed out and I can't input any different value
Am I missing something??
« Reply #15 on: January 28, 2010, 08:05:56 AM »
Saumur,
Are you using the demo version ?
Phil
« Reply #16 on: January 28, 2010, 08:07:51 AM »
I will post a screenshot of the box I am meaning in a few mins.
OK heres where I mean you enter the dimension.
« Last Edit: January 28, 2010, 08:12:50 AM by Hood »
« Reply #17 on: January 28, 2010, 04:55:29 PM »
Hey guys,
no, I don't use the demo.
Also Hood my table is different from yours, instead of rapid dia mine says safe Z.... why???
Thanks....
« Reply #18 on: January 28, 2010, 04:58:18 PM »
Sounds like you are using a mill profile rather than a turn profile. Have a look at Ports and Pins and see if the last tab says Turn Options or Mill Options.
« Reply #19 on: January 28, 2010, 05:00:47 PM »
Hey man,
it's a turn profile, no doubt, I even cheked.
Seriously I have no words to describe what's going on...
