Hello Guest it is October 21, 2026, 01:59:11 PM
Author Topic: trouble with probe  (Read 10409 times)
trouble with probe
« on: January 23, 2010, 07:12:08 PM »
I am setting up a gageblock probe When I touch the probe to the bit the probe light flashes irregularly.  Anybody have a suggestion.  If it is not on solid it may not detect the contact.
Offline Mattw
  •  41 41
Re: trouble with probe
« Reply #1 on: January 23, 2010, 11:20:27 PM »
May need a little more info on your setup.  If you are counting on an electrical path through your spindle bearings, you could get flaky results.  I recently got to inspect a bearing on a 600hp motor.  Voltage was building up in the rotor, and the only path to ground was through the bearings.  If there was contact all the time, the voltage would never build up.  However, it would build to the point that it would arc through the lube, and create a pit on the race.  High velocity edm machining!
Back to my point, try to remove as much of the unknowns from your electrical path by connecting a conductor from the probe to the table.
« Reply #2 on: January 24, 2010, 12:05:12 PM »
Thank you for your reply.  I've touched it to every surface I can reach and I get the same flashing.  I have a legacy ornamental mill with a porter-cable router.
Offline Mattw
  •  41 41
« Reply #3 on: January 24, 2010, 07:52:49 PM »
How about some photos of your setup?
