Hello Guest it is October 21, 2026, 03:44:30 AM
Author Topic: Anyone Here Have Experience Milling 6061-T651 Wrought Plate?  (Read 137180 times)
vintageracer
Re: Anyone Here Have Experience Milling 6061-T651 Wrought Plate?
« Reply #20 on: January 18, 2010, 12:53:36 PM »
I machined some 6061-T651 plate on the weekend.
1/4" 2 flute HSS at 4800rpm, 12ipm, flood coolant.
1/4" deep and full width cut.
Ran all day and still had a mirror like finish on the last piece.
Timothy
« Last Edit: January 18, 2010, 12:55:32 PM by vintageracer »
Offline bowber
  •  216 216
  • Kirkby Stephen,Cumbria, UK
« Reply #21 on: January 18, 2010, 02:50:13 PM »
Being a hobby user I use just about any materials at hand, some good some really horrible and have found that the biggest difference is flood coolant and climb milling.
I do try to use highish feed rates.
Mostly carbide tools, some of which are totally inappropriate, 4 or even 6 flute, and the only problems I've had have been when the coolant ran low and stopped, instant clogging and a snapped 10mm carbide bit.
Now that was a loud bang!
Steve
« Reply #22 on: January 18, 2010, 03:24:31 PM »
I don't need an excuse like "too fast" or "no coolant", I just drop my carbide on the floor or the table and break the edges off....
« Reply #23 on: January 18, 2010, 06:30:50 PM »
Dropping on the floor is so low-tech, and manual.  I just let Mach3/SmoothStepper jam the tool through my touchplate, or ram it into the side of the workpiece when probing.  :-)
« Reply #24 on: January 19, 2010, 03:30:37 AM »
Amateurs . .  ::)
Real pros buy name brand coated carbide cutters . .  position them carefully . . . get them up to max RPM . . .  and then jog at full speed directly into the hardened vice jaws     8)
« Reply #25 on: January 19, 2010, 05:09:01 AM »
Here Ya go Ray, the way it's done.....
« Reply #26 on: January 19, 2010, 06:00:41 AM »
Hey Bill, that looks more like friction stir welding than milling.  :)
Russ ;D
« Reply #27 on: January 19, 2010, 06:14:46 AM »
'friction stir welding', hmmm, could we have developed a brand new and exciting process? Problem is these random results.
« Reply #28 on: January 19, 2010, 06:22:59 AM »
Oh...its been around a while. But like you say, maintaining consistency with a milling machine would be a problem. ::)
Russ :)
« Reply #29 on: January 19, 2010, 08:32:54 AM »
Now that's impressive!  How did you manage to NOT break it?
