Hello Guest it is October 20, 2026, 05:04:40 PM
Author Topic: mpg ports and pins  (Read 9957 times)
mpg ports and pins
« on: January 14, 2010, 05:25:31 AM »
i have been having problems with mach turn and an mpg. i had a mpg connected to a pokeys , in ports and pins /mpg/ had port 10  pin 1 for A.port 10 pin 2 for B.decided to use pport  instead and so chose port 1 pin 10 for A. port1 pin 11 for B.so i save and works properly. when mach is shut down and restarted, the configuration of the pokeys, port 10 is there.if wont stay changed to port 1.
Re: mpg ports and pins
« Reply #1 on: January 14, 2010, 05:39:26 AM »
I think that is a problem with the later plugins, I had to delete the plugin before I could get rid of that problem if I recall. That wasnt a problem for me as I no longer use the PoKeys.
Make sure first though that you dont have the MPG set in the plugin, if you dont then you may have to delete the plugin and then reinstall it and start afresh.
« Reply #2 on: January 16, 2010, 04:53:53 AM »
thank you Hood, deleted all the pokeys plugins.reinstalled mach.no more problems. iam still using the pokeys , only thru hotkey combinations.
