Hello Guest it is October 21, 2026, 05:27:19 AM
Author Topic: Can you put a number to this DRO ?  (Read 38878 times)
Re: Can you put a number to this DRO ?
« Reply #10 on: January 13, 2010, 02:24:38 PM »
hmmmmm......don't think so. Must be buried in the Sys. Function.
« Reply #11 on: January 13, 2010, 02:37:52 PM »
I kind-of figure that this may be the sort of information that would open that 'can of worms' on this forum! I've dug around and found this info before but memory fails...
Bill C.
« Reply #12 on: January 13, 2010, 02:42:28 PM »
It's a terminology thing....
« Reply #13 on: January 13, 2010, 02:45:43 PM »
« Last Edit: January 13, 2010, 02:53:31 PM by Overloaded »
« Reply #14 on: January 13, 2010, 02:55:40 PM »
Overloaded, What's the .gif file on your post. Says it's 'not allowed'...?
   Nevermind! I must have been to eager to see....!
Thanks for the info!
« Last Edit: January 13, 2010, 02:57:42 PM by BClemens »
« Reply #15 on: January 13, 2010, 04:20:32 PM »
Overloaded is the winner. ;D thank you.
In the Mach3 OEM codes it describes Oem 33 as "X axis Ref Sw DRO"
Maybe the file could be updated
Phil
« Reply #16 on: January 13, 2010, 04:28:14 PM »
That's Hood's baby...lets ask him nicely and he just might add the description.
« Reply #17 on: January 13, 2010, 04:33:06 PM »
Phil, I have been working on the list for a while. This is some of the prep. work going into Rev.4. I will post a different version in Hoods sticky in General.
« Reply #18 on: January 13, 2010, 04:34:21 PM »
Not mine, its just from the wiki and put in a xml to make it downloadable and easier to search.
Think Brett will be posting a new list sometime with better descriptions and maybe even the new numbers for Rev4
Edit, now that is a serious state of affairs, I have been outyped by a Redneck ;D
« Reply #19 on: January 13, 2010, 04:50:40 PM »
Well it DID look like a bit much for you to author....but I assumed you would have no trouble editing it. ::)
Russ :)
