Hello Guest it is November 13, 2026, 05:45:43 PM
Author Topic: BRIDGEPORT SERIES II CNC MILL W/ BOSS 6 CONTROL RETROFIT  (Read 75310 times)
Re: BRIDGEPORT SERIES II CNC MILL W/ BOSS 6 CONTROL RETROFIT
« Reply #30 on: May 11, 2011, 10:53:02 AM »
Joe,
Good job on the retrofit! I did a Series I BOSS 6 and kept the original steppers, Gecko 203's and run then @ 65V/7A. I have had no problems at all for the last 2 years. I also limit my speeds to 100 IPM. Just be aware that your BOSS 5 has no gearing (belt) so your speeds will be slower. Boss 6 and newer have a 2.5:1 drive. I think you will be well served for putting these machines back in production if they aren't wore out. Mine still holds tenths. I reused as many parts as I could to save on components including the original (modified) heat sinks for the Geckos.
Good job.
Dean
« Last Edit: May 11, 2011, 10:54:38 AM by deanq »
