Hello Guest it is November 13, 2026, 03:02:59 PM
Author Topic: Possible wrong settings? or hardware?  (Read 27595 times)
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Possible wrong settings? or hardware?
« Reply #10 on: September 23, 2006, 09:50:33 PM »
Hi, Twin Staged
Did you clik on APPLY, then ok.
Chip
« Reply #11 on: September 24, 2006, 01:47:38 AM »
yes and all the pin numbers stayed where i put them on the restart.  It doesnt make sense to me why it didn't affect the proper axis.
Offline Chip
  •  2,055 2,055
« Reply #12 on: September 24, 2006, 02:00:49 PM »
Hi, Twin Staged
Post your pin # x,y,z,a, as thay appear in Config, Ports Pins, Motor Outputs and which axis moves when you jog x,y,z.a.
Thay still must be incorrect.
Thank's Chip
« Reply #13 on: September 27, 2006, 05:27:00 PM »
right now my  i have:
    Step     Dir
X     8       9
Y     4      5
Z     2       3
A     6       7
When i Jog X my Z moves
when I jog Z my A moves
when i jogY my Y moves
when i jog A my Xmoves
Offline Chip
  •  2,055 2,055
« Reply #14 on: September 27, 2006, 08:09:21 PM »
Hi, twin staged
Click on Config, Ports and Pins, Motor Outputs, enter the following  info. below, then Click on Apply then OK.
Now Reset, Jog all Axis's to check if Ok, Exit Program and Restart, If it doesn't reload the new setting's, about the only thing that could be
bad is your XML file is write protected.
    Step     Dir
X    6       7
Y    4      5
Z    8       9
A    2       3
If this docent please post your Mach3Mill.XML file
Thank"s Chip
