Hello Guest it is October 20, 2026, 11:11:51 PM
Author Topic: Any tutorial for the engraving wizzard  (Read 11349 times)
« on: January 11, 2010, 05:51:58 PM »
  I cant seem to get any code when I enter infro on the engraving wizzard. Any manual for this?   Thanks   Jim
Re: Any tutorial for the engraving wizzard
« Reply #1 on: January 11, 2010, 05:58:23 PM »
Hi Jim,
Make sure you have a FONT selected and then hit the WRITE key.
HTH,
Russ
« Last Edit: January 11, 2010, 06:01:30 PM by Overloaded »
« Reply #2 on: January 11, 2010, 06:05:47 PM »
  I never hit" WRITE" Russ.. that worked thanks!
« Reply #3 on: January 11, 2010, 06:08:30 PM »
No prob Jim.
Don't think there is a tutorial, the rest of it is pretty straightforward.
Good luck,
Russ
« Reply #4 on: January 11, 2010, 06:19:52 PM »
You may want try a serach and see what you find. I don't know of any specific manual and only
tried it a long time ago. You just select the font,input where you want to start along with feed rate,
pick the direction of how the text will be placed, input the size and cutting  depth, type something, click the wirte
button, return to mach a there is the code for what you typed. Can only do a single line of text though.
