Hello
Guest
it is
November 07, 2026, 10:52:18 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
Non English Forums
Spanish
Elipse con lazy cam
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Elipse con lazy cam (Read 14333 times)
merolivol
7
Elipse con lazy cam
on:
January 11, 2010, 12:02:17 PM »
Tengo un problema, estoy trazando elipses con auto cad y al pasar el dxf a lazy cam las reconoce como un poligono, se puede modificar esta situacion?
ger21
6,295
Re: Elipse con lazy cam
Reply #1 on:
January 11, 2010, 12:38:07 PM »
Use v12 dxf.
merolivol
7
Reply #2 on:
January 11, 2010, 07:07:05 PM »
Gracias Gerry
Otra pregunta, que ventajas tiene la version profesional de Lazy Cam , en la demo tengo que descontar los diametros de los cortadores para que me salga la plantilla a medida, sigue igual gracias.
ger21
6,295
Reply #3 on:
January 11, 2010, 09:52:27 PM »
Sorry, no habla espaniol
merolivol
7
Reply #4 on:
January 12, 2010, 08:42:27 AM »
Ok Gerry no problem.
LESV
10
Reply #5 on:
January 19, 2010, 07:31:42 PM »
Gerry, what is "v12 dxf"
ger21
6,295
Reply #6 on:
January 19, 2010, 09:04:48 PM »
Version 12 format .dxf files.
Reply #7 on:
January 20, 2010, 08:12:27 AM »
In the Lazyturn Manual, Appendix "C' ( located in Members Docs) you will find info on DXF. The info is not all inclusive but should be infomative.
Print
Pages:
1
Go Up
« previous
next »
