Hello Guest it is October 20, 2026, 07:07:11 PM
Author Topic: Version R3.042.035 No Go  (Read 19480 times)
« on: January 08, 2010, 03:25:47 AM »
Hi All
I installed Version R3.042.035 and it will not open. Error found ARTCODE 3092. Open the error report further and it referes to shuttpro.dll giving problems. Tried a few times and system restore got me running again. Does anyone know why the new version will not open?  ???
Regards
Noel
Re: Version R3.042.035 No Go
« Reply #1 on: January 08, 2010, 04:49:29 AM »
If you dont use the Shuttle Pro try going into C:\Mach3\Plugins and delete the Shuttle one and see if that helps.
« Reply #2 on: January 08, 2010, 05:20:45 AM »
I Don't use the Shuttlepro so will give it a go tomorrow if I can stop my building leaking in this TROPICAL DOWNPOUR AHHH
Thanks Noel
« Reply #3 on: January 08, 2010, 05:31:48 AM »
Hood,
got the same error, cannot find any shuttlepro.dll in the plugins folder.
regards
Gianluca
« Reply #4 on: January 08, 2010, 05:35:08 AM »
will report it to Art and see what he reckons, in the mean time probably best to go back to a version before 030 unless you specifically need something in the newer revisions.
« Reply #5 on: January 22, 2010, 05:07:10 PM »
just tried to install new version on a lathe setup as well and it will not load either. System restore got it back to normal again
Noel
« Reply #6 on: January 23, 2010, 05:58:02 AM »
Hi All
Probably why .036 is the current lockdown. Try that one.
« Reply #7 on: January 24, 2010, 12:50:25 AM »
Yep All good. Fixed it on the mill and the lathe.
Regards
Noel
Re: Version R3.042.036 artcode errors
« Reply #8 on: February 05, 2010, 07:06:53 AM »
Hey,
I'm getting artcode error 8877 and 9991
What to do, what to do?
I'm running XP pro, latest .036 mach, latest smooth stepper. When I try to run
the following Macro is when I get error. It worked fine previously and currently
on another machine. I also get the same error with .032
  Here is the M command it locks on:
REM M1051 For GRIND To DIMENSION
Option Explicit
Dim FinishDim As Double
Dim ToGrind As Double
Dim HoldToGrind As Double
Dim Current As Double
Dim Remainder As Double
Dim SparkoutCounter As Integer
Dim RoughToGo As Double
Dim FinishToGo As Double
Dim RoughInc
Dim FinishInc
Dim Sparkouts As Integer
Dim LeftX
Dim RightX
Dim LeftFeedX
Dim RightFeedX
Dim LeftDwell
Dim RightDwell
LeftDwell = GetOEMDRO(1110)
RightDwell = GetOEMDRO(1120)
FinishDim = GetOEMDRO(1056)
ToGrind = 0
Current = 0
Remainder = 0
SparkoutCounter = 0
RoughToGo = 0
FinishToGo = 0
RoughInc = GetOEMDRO(1052)
FinishInc = GetOEMDRO(1053)
Sparkouts = GetOEMDRO(1054)
LeftX = GetOEMDRO(1060)
RightX = GetOEMDRO(1061)
LeftFeedX = GetOEMDRO(1162)
RightFeedX = GetOEMDRO(1163)
Current = GetOEMDRO(801)
ToGrind = Current - FinishDim
HoldToGrind = ToGrind * 1000000
ToGrind = HoldToGrind * .000001
Current = 0
While ((ToGrind + .00001) >= .001)
   ToGrind = ToGrind - .001
   RoughToGo = RoughToGo + 1
Wend
While ((ToGrind + .00001) >= .0001)
   ToGrind = ToGrind - .0001
   FinishToGo = FinishToGo + 1
Wend
If (RoughToGo >0) Then
   Code "M8 M3"
   Code "G04 P2."
   While ((Current + (RoughInc / 10)) <= RoughToGo)
      rem turn On side travel
      If GetUserLed (1100) Then
         Code "G90G01 X" & LeftX & "F" & RightFeedX
         Code "G91G00 Y-" & (RoughInc / 10000)
         Code "G04 P" & LeftDwell
         Code "G90G01 X" & RightX & "F" & LeftFeedX
         Code "G04 P" & RightDwell
         Current = Current + (RoughInc / 10)
         Remainder = RoughToGo - Current
      End If
      If ((Current + (RoughInc / 10)) <= RoughToGo) Then
         If GetUserLed (1101) Then
         End If
      End If
   Wend
End If
If (Remainder > 0) Then
Remainder = Remainder * 10
FinishToGo = FinishToGo + Remainder
End If
Current = 0
Remainder = FinishToGo
If (FinishToGo > 0) Then
   Code "M8 M3"
   Code "G04 P2."
   While (Current < (FinishToGo - FinishInc))
         Code "G91G00 Y-" & (FinishInc / 10000)
         Current = Current + FinishInc
         Remainder = FinishToGo - Current
      End If
      If (Current < (FinishToGo - FinishInc)) Then
         End If
      End If
   Wend
End If
   Code "M8 M3"
   Code "G04 P2."
      Code "G91G00 Y-" & (Remainder / 10000)
      Remainder = 0
   End If
         Remainder = 0
      End If
   End If
End If
rem last final Left over
Remainder = Current - FinishDim
HoldToGrind = Remainder * 1000000
Remainder = HoldToGrind * .000001
If (FinishDim <> Current) Then
   Code "M8 M3"
   Code "G04 P2."
      Code "G90G00 Y" & FinishDim
      Remainder = 0
   End If
         Remainder = 0
      End If
   End If
End If
If ((RoughToGo + FinishToGo) > 0) Then
   Code "M8 M3"
   Code "G04 P2."
   If GetOEMLED(1102) Then
      While (Sparkouts > SparkoutCounter)
         SetUserLED(1110,0)
         SetUserLED(1111,1)
         SetUserLED(1111,0)
         SetUserLED(1110,1)
         SparkoutCounter = SparkoutCounter + 1
      Wend
   End If
   If GetOEMLED(1103) Then
         SetUserLED(1111,0)
         SetUserLED(1110,1)
         SetUserLED(1110,0)
         SetUserLED(1111,1)
      Wend
   End If
End If
Code "M9 M5"
Any Ideas?
T. Byrd
