Hello Guest it is October 23, 2026, 08:03:44 PM
Author Topic: Inporting DXF to Mach3  (Read 12735 times)
« on: January 07, 2010, 05:21:05 AM »
Hello,
I am completly new, working with the demo version of Mach3 the last last two weeks.
Intend to buy a license after evaluation.
I have a question what´s boring me the last couple of days
Is it possible from a 3D drawing (Acad ver.2007) saved as dxf to inport this into Mach3 and convert it in G-Code like it is  ?
     or do I need to edit de G code manually (or the dxf file)
because after converting , I don´t see my original drawing I made in ACAD on the Mach Display.
Is there a forum for these kind of questions?
Roland
Re: Inporting DXF to Mach3
« Reply #1 on: January 07, 2010, 05:33:31 AM »
You will need to use LazyCAM for that. I dont use it myself so afraid I cant be much help but there is a section here that is dedicated to LazyCAM so probably worth posting there.
 If however it is a true 3D part then I think you will need a better (read  expensive) CAM programme than LazyCAM.
« Reply #2 on: January 07, 2010, 11:48:28 AM »
Thanks to coming back  :)
Offline bowber
  •  216 216
  • Kirkby Stephen,Cumbria, UK
« Reply #3 on: January 07, 2010, 12:35:21 PM »
For 3D files I use meshcam, cheap and faily simple to use, it is only for 3D machining so don't expect ot be able to do 2.5D cutting with it.
There is a free program available, http://www.mecsoft.com/freemill.shtml
I tried is a few years ago and gave up but having looked back at it now it looks to have been worked on so may have improved.
Steve
« Reply #4 on: January 07, 2010, 03:54:03 PM »
LazyCAM will NOT work with a 3D .dxf file. I also use MeshCAM for 3D. Another option is Vectric's Cut3D.
