Hello Guest it is November 13, 2026, 03:47:25 PM
Author Topic: Mach3 sometimes doesnt move with THC on  (Read 11203 times)
Offline Bobo
  •  41 41
    • Haus Metalworks
« on: September 18, 2006, 09:27:20 PM »
I'm having some trouble getting my THC300 working consistently. Many times directly after the arc fires with the m3 command Mach3 will not continue with the program even though I get an Arc OK inside Mach3 and on the THC300 controller. I'm sure it's probably something in my profile. I am testing with a very simple straight line cut.
N0030 G20 (Units: Inches)
N0040 G53 G90 G40
N150 M3
N200 G1 Y48 F100
N300 M5
N310 M30
M3 is just DoSpinCW() and I have my metal on a slight slant to test. Sometimes it works well and other times Mach3 will not move on to line no N200 but I can see the z axis changing from the THC. I am using no dwell.
Thanks for any help.
Re: Mach3 sometimes doesnt move with THC on
« Reply #1 on: September 19, 2006, 06:35:54 PM »
I am sorry I have never used that THC :( if no one can help here we should will contact Jim :)
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: September 24, 2006, 08:08:26 AM »
I haven't seen that one. Could you send me your XML and let me have a look at it.
It is possible that you XML is corrupt.
Jim Cullins Sound Logic
