Hello Guest it is October 14, 2026, 06:51:22 AM
Author Topic: Dinosaur skeletons ( Pictures and files included )  (Read 123380 times)
ynneb
« on: September 17, 2006, 09:57:58 PM »
A couple of years ago I made this skeleton. Attached is the drawing file.
You may need to edit it in depending on your machine size, final object size and material thickness.
« Last Edit: September 17, 2006, 10:25:22 PM by ynneb »
ynneb
Re: Dinosaur skeletons
« Reply #1 on: September 17, 2006, 10:02:03 PM »
Here is a different one I made using these attached files. Agaian, you will need to edit them to suit.
These are unusual files, in that they are a font for each dino. They take some mucking around to get right though.
The wing span of the model I made just under 3 m.
« Last Edit: September 17, 2006, 10:03:57 PM by ynneb »
ynneb
Re: Dinosaur skeletons ( Pictures and files included )
« Reply #2 on: November 22, 2006, 03:50:16 PM »
Any one used this code to make one for them self yet ?
« Reply #3 on: June 14, 2007, 07:42:51 PM »
I am looking for a CNC machine now. I have a friend that has a Laser & he just scans a line art of what he wants to cut. Like your Dinosaur ( which are pretty cool ) . Can Artsoft do this? I have PhotoShop & the line art for a large puzzel.
ynneb
« Reply #4 on: June 14, 2007, 08:03:09 PM »
"Artsoft:" is machine control software. It turns a PC into a machine controller.
You need CAM and CAD software to make the gcode that our software will then run.
« Reply #5 on: June 14, 2007, 08:18:04 PM »
Thank you ... Any suggestions on buying those?
« Reply #6 on: July 20, 2007, 04:52:32 PM »
wow I love your raptor when I started to make my mill I said to my daughter I would make here a dinosour and I think you one is cool as soon as I fiinish my mill i will make one where did you get the pattern from
http://perryman.f2s.com/projects/cnc%20mill/cnc%20mill.html
ynneb
« Reply #7 on: July 20, 2007, 08:28:49 PM »
Check through this thread http://www.cnczone.com/forums/showthread.php?t=5276 it has many pages of responses including shared file etc.
Its very inspiring.
